Extensions 2.0 Monitoring configurations limit
Hi everyone,
I’ve built a Python-based custom script extension (v2.0) that runs locally on each OneAgent host (no remote endpoints).
Each endpoint in the extension definition corresponds to a single script executed on the host itself.
Because these scripts are host-specific, we currently create a separate monitoring configuration per host rather than at the Host Group or Environment level. Our Dynatrace Managed cluster now contains roughly 1 000–2 000 hosts (mix of on-prem VMs, EC2 instances, and K8s nodes) that all require this extension.
I’d appreciate clarification on two points:
  1. Configuration-per-extension limit: I’ve read that each extension is capped at 100 monitoring configurations. Is this limit hard-coded, or can it be increased on a Dynatrace Managed deployment?
  2. Scaling strategy: If the limit is fixed and we must create multiple copies of the extension to cover every host: Are there recommended approaches for minimizing operational overhead (e.g., version alignment, automated rollout, naming conventions)? Any lessons learned from maintaining many near-identical extensions?
Thanks in advance for your insights!
- Roei
Hi 🙂
Same issue and same question here !
Thanks in advance.
