Error When Deploying Configuration For SSL Certificate Monitor Extension
Hi Dynatrace Community,
I hope you’re all well.
I’m in the process of deploying the SSL Certificate Monitoring Extension in my DEV Environment for a pilot and I keep getting the Error below when I try to activate the configuration:
  • MONITORING_SOURCE_OUTDATED
The configuration is being deployed locally at Host Group level, and I am wondering if the version of the OA running on these hosts might be the problem.
I have installed the latest version of the extension in the environment that contains the following notes:
v1.10.26
This version raises the cluster version to 1.318+.
  • Improved compatibility with the Infrastructure and Operations app
The OA Version on the Hosts is 1.309.75.20250507-164721, so I suspect there might be an issue with there.
I couldn’t find anything along those lines when reviewing release notes, so I was hoping to get some assistance with how to tackle this.
Thank you in advance,
Victor Correa
hi @victor_correa,
Starts from v1.10.17 it looks for EEC version1.313+ for support as minimal requirement. Yes, you are right this is OA version outdated.
Refer the attached image for the same.
Hope this helps. Happy Dynatrac’ingThanks
