Error while running dynakube.yaml
We have k8s behind proxy and are trying to install full-stack observe. kubernetes-csi.yaml was successful but when I run dynakube.yaml I get the following error:
# kubectl apply -f dynakube.yaml
Error from server (InternalError): error when creating “dynakube.yaml”: Internal error occurred: failed calling webhook “v1beta3.dynakube.webhook.dynatrace.com”: failed to call webhook: the server could not find the requested resource
Could this be due to network connectivity? pods are:
# kubectl get pods -n dynatrace
NAME READY STATUS RESTARTS AGE
dynatrace-oneagent-csi-driver-2zprh 3/4 CrashLoopBackOff 18 (5m3s ago) 26m
dynatrace-oneagent-csi-driver-8zjjt 3/4 CrashLoopBackOff 18 (5m6s ago) 26m
dynatrace-oneagent-csi-driver-dp5vb 3/4 CrashLoopBackOff 18 (4m55s ago) 26m
dynatrace-oneagent-csi-driver-pp2nj 3/4 CrashLoopBackOff 18 (4m50s ago) 26m
dynatrace-oneagent-csi-driver-rsvdm 4/4 CrashLoopBackOff 19 (5m2s ago) 26m
dynatrace-oneagent-csi-driver-slpzs 3/4 CrashLoopBackOff 18 (4m54s ago) 26m
dynatrace-oneagent-csi-driver-zxx8v 3/4 CrashLoopBackOff 19 (13s ago) 26m
dynatrace-operator-587886577d-wzr4k 1/1 Running 0 23h
dynatrace-webhook-6d878bcc77-82l5n 1/1 Running 0 23h
dynatrace-webhook-6d878bcc77-ttgpr 1/1 Running 0 23h
describe warning:
Warning BackOff 2m27s (x131 over 27m) kubelet Back-off restarting failed container server in pod dynatrace-oneagent-csi-driver-rsvdm_dynatrace
Hi @kduebc ,
I had this issue, it was resolved by updating the active-gate service name in the no-proxy annotation.
If you already have it from a previous release, doublecheck it as the service names change with the 1.4+ operator version.
annotations:
    feature.dynatrace.com/no-proxy: ".dynatrace.svc,.artifactory.gcp.xxx,.amazonaws.com" #private repo
It looks like Dynatrace Operator can’t communicate with webhook. Do you see that all of your CSI driver pods are in back-off state? Without running them you can’t deploy an operator. Could you describe one pod of CSI driver and provide output? In example: kubectl describe pod dynatrace-oneagent-csi-driver-zxx8v -n=dynatrace
Following is the output
<br>Name: dynatrace-oneagent-csi-driver-q4tlg<br>Namespace: dynatrace<br>Priority: 1000000<br>Priority Class Name: dynatrace-high-priority<br>Service Account: dynatrace-oneagent-csi-driver<br>Node: s-k8s-w21/10.1.90.224<br>Start Time: Mon, 10 Mar 2025 10:45:50 +1000<br>Labels: app.kubernetes.io/component=csi-driver<br>app.kubernetes.io/name=dynatrace-operator<br>app.kubernetes.io/version=1.4.1<br>controller-revision-hash=67d78b6557<br>internal.oneagent.dynatrace.com/app=csi-driver<br>internal.oneagent.dynatrace.com/component=csi-driver<br>pod-template-generation=1<br>Annotations: cluster-autoscaler.kubernetes.io/enable-ds-eviction: false<br>cni.projectcalico.org/containerID: f9df8604943a7764319945db68c9f5cbf8f30fc0e12e259709b4f5035d6906f4<br>cni.projectcalico.org/podIP: 10.244.187.34/32<br>cni.projectcalico.org/podIPs: 10.244.187.34/32<br>dynatrace.com/inject: false<br>kubectl.kubernetes.io/default-container: provisioner<br>Status: Running<br>IP: 10.244.187.34<br>IPs:<br>IP: 10.244.187.34<br>Controlled By: DaemonSet/dynatrace-oneagent-csi-driver<br>Init Containers:<br>csi-init:<br>Container ID: cri-o://d4306d2b7a31717ca0226288e0cd7502948560cfdcc2769518c20fdf15757bd5<br>Image: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Image ID: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Port: <none><br>Host Port: <none><br>Args:<br>csi-init<br>State: Terminated<br>Reason: Completed<br>Exit Code: 0<br>Started: Mon, 10 Mar 2025 10:45:55 +1000<br>Finished: Mon, 10 Mar 2025 10:45:56 +1000<br>Ready: True<br>Restart Count: 0<br>Limits:<br>cpu: 50m<br>memory: 100Mi<br>Requests:<br>cpu: 50m<br>memory: 100Mi<br>Environment: <none><br>Mounts:<br>/data from data-dir (rw)<br>/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-pzp4g (ro)<br>Containers:<br>server:<br>Container ID: cri-o://63084fda638277f4acdd49ac990b990957160b38ee680fb8aa8c44d5c0be7937<br>Image: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Image ID: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Ports: 9808/TCP, 8080/TCP<br>Host Ports: 0/TCP, 0/TCP<br>Args:<br>csi-server<br>--endpoint=unix:/csi/csi.sock<br>--node-id=$(KUBE_NODE_NAME)<br>State: Waiting<br>Reason: CrashLoopBackOff<br>Last State: Terminated<br>Reason: Error<br>Exit Code: 1<br>Started: Mon, 10 Mar 2025 10:56:42 +1000<br>Finished: Mon, 10 Mar 2025 10:56:43 +1000<br>Ready: False<br>Restart Count: 7<br>Limits:<br>cpu: 50m<br>memory: 100Mi<br>Requests:<br>cpu: 50m<br>memory: 100Mi<br>Liveness: http-get http://:healthz/healthz delay=15s timeout=10s period=15s #success=1 #failure=5<br>Environment:<br>POD_NAMESPACE: dynatrace (v1:metadata.namespace)<br>KUBE_NODE_NAME: (v1:spec.nodeName)<br>Mounts:<br>/csi from plugin-dir (rw)<br>/data from data-dir (rw)<br>/tmp from tmp-dir (rw)<br>/var/lib/kubelet/pods/ from mountpoint-dir (rw)<br>/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-pzp4g (ro)<br>provisioner:<br>Container ID: cri-o://01c97c0ddd72ee46093c3306616cbbbeaa19d23d065a37df1393a1a5cdfa466d<br>Image: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Image ID: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Ports: 10090/TCP, 8090/TCP<br>Host Ports: 0/TCP, 0/TCP<br>Args:<br>csi-provisioner<br>--health-probe-bind-address=:10090<br>State: Running<br>Started: Mon, 10 Mar 2025 10:45:58 +1000<br>Ready: True<br>Restart Count: 0<br>Requests:<br>cpu: 300m<br>memory: 100Mi<br>Liveness: http-get http://:livez/livez delay=5s timeout=1s period=5s #success=1 #failure=3<br>Startup: exec [/usr/local/bin/dynatrace-operator startup-probe] delay=0s timeout=5s period=10s #success=1 #failure=1<br>Environment:<br>POD_NAMESPACE: dynatrace (v1:metadata.namespace)<br>modules.json: {<br>"csiDriver": true,<br>"activeGate": true,<br>"oneAgent": true,<br>"extensions": true,<br>"logMonitoring": true,<br>"edgeConnect": true,<br>"supportability": true,<br>"kspm": true<br>}<br><br>Mounts:<br>/data from data-dir (rw)<br>/tmp from tmp-dir (rw)<br>/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-pzp4g (ro)<br>registrar:<br>Container ID: cri-o://6f7b9c0421b521383147bd98a678af140752599501a2f3c63102a1f3b66f9b29<br>Image: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Image ID: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Port: <none><br>Host Port: <none><br>Command:<br>csi-node-driver-registrar<br>Args:<br>--csi-address=/csi/csi.sock<br>--kubelet-registration-path=$(DRIVER_REG_SOCK_PATH)<br>State: Waiting<br>Reason: CrashLoopBackOff<br>Last State: Terminated<br>Reason: Error<br>Exit Code: 1<br>Started: Mon, 10 Mar 2025 10:54:43 +1000<br>Finished: Mon, 10 Mar 2025 10:55:14 +1000<br>Ready: False<br>Restart Count: 6<br>Limits:<br>cpu: 20m<br>memory: 30Mi<br>Requests:<br>cpu: 20m<br>memory: 30Mi<br>Environment:<br>DRIVER_REG_SOCK_PATH: /var/lib/kubelet/plugins/csi.oneagent.dynatrace.com/csi.sock<br>Mounts:<br>/csi from plugin-dir (rw)<br>/registration from registration-dir (rw)<br>/var/lib/kubelet/plugins/csi.oneagent.dynatrace.com/ from lockfile-dir (rw)<br>/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-pzp4g (ro)<br>liveness-probe:<br>Container ID: cri-o://8c27d4c70ca8c61ed796bc4cded1833acf8ab60f03d3cb971d6e10a1d76a24f8<br>Image: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Image ID: s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a<br>Port: <none><br>Host Port: <none><br>Command:<br>livenessprobe<br>Args:<br>--csi-address=/csi/csi.sock<br>--health-port=9808<br>--probe-timeout=9s<br>State: Running<br>Started: Mon, 10 Mar 2025 10:46:02 +1000<br>Ready: True<br>Restart Count: 0<br>Limits:<br>cpu: 20m<br>memory: 30Mi<br>Requests:<br>cpu: 20m<br>memory: 30Mi<br>Environment: <none><br>Mounts:<br>/csi from plugin-dir (rw)<br>/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-pzp4g (ro)<br>Conditions:<br>Type Status<br>Initialized True<br>Ready False<br>ContainersReady False<br>PodScheduled True<br>Volumes:<br>registration-dir:<br>Type: HostPath (bare host directory volume)<br>Path: /var/lib/kubelet/plugins_registry/<br>HostPathType: Directory<br>plugin-dir:<br>Type: HostPath (bare host directory volume)<br>Path: /var/lib/kubelet/plugins/csi.oneagent.dynatrace.com/<br>HostPathType: DirectoryOrCreate<br>data-dir:<br>Type: HostPath (bare host directory volume)<br>Path: /var/lib/kubelet/plugins/csi.oneagent.dynatrace.com/data<br>HostPathType: DirectoryOrCreate<br>mountpoint-dir:<br>Type: HostPath (bare host directory volume)<br>Path: /var/lib/kubelet/pods/<br>HostPathType: DirectoryOrCreate<br>lockfile-dir:<br>Type: EmptyDir (a temporary directory that shares a pod's lifetime)<br>Medium:<br>SizeLimit: <unset><br>tmp-dir:<br>Type: EmptyDir (a temporary directory that shares a pod's lifetime)<br>Medium:<br>SizeLimit: <unset><br>kube-api-access-pzp4g:<br>Type: Projected (a volume that contains injected data from multiple sources)<br>TokenExpirationSeconds: 3607<br>ConfigMapName: kube-root-ca.crt<br>ConfigMapOptional: <nil><br>DownwardAPI: true<br>QoS Class: Burstable<br>Node-Selectors: <none><br>Tolerations: ToBeDeletedByClusterAutoscaler:NoSchedule op=Exists<br>kubernetes.io/arch=amd64:NoSchedule<br>kubernetes.io/arch=arm64:NoSchedule<br>kubernetes.io/arch=ppc64le:NoSchedule<br>kubernetes.io/arch=s390x:NoSchedule<br>node-role.kubernetes.io/control-plane:NoSchedule op=Exists<br>node-role.kubernetes.io/master:NoSchedule op=Exists<br>node.kubernetes.io/disk-pressure:NoSchedule op=Exists<br>node.kubernetes.io/memory-pressure:NoSchedule op=Exists<br>node.kubernetes.io/not-ready:NoExecute op=Exists<br>node.kubernetes.io/pid-pressure:NoSchedule op=Exists<br>node.kubernetes.io/unreachable:NoExecute op=Exists<br>node.kubernetes.io/unschedulable:NoSchedule op=Exists<br>Events:<br>Type Reason Age From Message<br>---- ------ ---- ---- -------<br>Normal Scheduled 13m default-scheduler Successfully assigned dynatrace/dynatrace-oneagent-csi-driver-q4tlg to s-k8s-w21<br>Normal Pulling 13m kubelet Pulling image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a"<br>Normal Pulled 13m kubelet Successfully pulled image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a" in 81.178869ms (81.190076ms including waiting)<br>Normal Created 13m kubelet Created container csi-init<br>Normal Started 13m kubelet Started container csi-init<br>Normal Pulled 13m kubelet Successfully pulled image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a" in 60.464681ms (60.476568ms including waiting)<br>Normal Pulling 13m kubelet Pulling image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a"<br>Normal Started 13m kubelet Started container provisioner<br>Normal Pulled 13m kubelet Successfully pulled image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a" in 59.984636ms (59.994808ms including waiting)<br>Normal Pulling 13m kubelet Pulling image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a"<br>Normal Pulled 13m kubelet Successfully pulled image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a" in 61.40022ms (61.411261ms including waiting)<br>Normal Created 13m kubelet Created container provisioner<br>Normal Created 13m kubelet Created container registrar<br>Normal Started 13m kubelet Started container registrar<br>Normal Pulling 13m kubelet Pulling image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a"<br>Normal Pulled 13m kubelet Successfully pulled image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a" in 70.71851ms (70.723591ms including waiting)<br>Normal Pulling 13m (x2 over 13m) kubelet Pulling image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a"<br>Normal Created 13m kubelet Created container liveness-probe<br>Normal Started 13m kubelet Started container liveness-probe<br>Normal Pulled 13m kubelet Successfully pulled image "s-harbor.example.com/atis/dynatrace/dynatrace-operator@sha256:123275d7ff395a29bf5524fd5d69573e593d80e7597a40fde9953c0dd78ffc5a" in 60.778914ms (60.785462ms including waiting)<br>Normal Started 12m (x2 over 13m) kubelet Started container server<br>Normal Created 12m (x2 over 13m) kubelet Created container server<br>Warning BackOff 2m57s (x60 over 12m) kubelet Back-off restarting failed container server in pod dynatrace-oneagent-csi-driver-q4tlg_dynatrace(1160d563-a955-40a4-a462-c404a9a9953b)
