Operator Deployment - Dynakube error 502
Hello, I am having an issue properly deploying dynatrace within our openshift cluster.
I have all the necessary information regarding on how to connect to dynatrace, but unable to successfully deployed the dynakube CR. Here is the yaml that I am attempting to deploy.
apiVersion: dynatrace.com/v1beta1kind: DynaKubemetadata:name: dynakubenamespace: dynatracespec:apiUrl: https://{environmentid}.live.dynatrace.com/apioneAgent:classicFullStack:image: ""tolerations:- effect: NoSchedulekey: node-role.kubernetes.io/masteroperator: Exists- effect: NoSchedulekey: node-role.kubernetes.io/control-planeoperator: ExistsautoUpdate: falseskipCertCheck: truetokens: dynakubeactiveGate:capabilities:- routing- kubernetes-monitoring- dynatrace-apiimage: ""resources:requests:cpu: 500mmemory: 512Milimits:cpu: 1000mmemory: 1.5GiWhen attempting to deploy this yaml, I get an error immediately. That error is:status:activeGate: {}conditions:- lastTransitionTime: '2024-03-26T15:16:52Z’message: "response error, can’t unmarshal json response 502: invalid character ‘<’ looking for beginning of value\n\tresponse error, can’t unmarshal json response 502: invalid character ‘<’ looking for beginning of value"reason: TokenErrorstatus: 'False’type: TokensThe weird thing about this is, I have attempted to modify the yaml numerous times, and on two different occasions the CR was proceeding. The second time I was able to get it to attempt to spin up the oneagent pods, there were a few pods that kept getting image pullback errors. I ended up pulling the image to a local registry, tagging appropriately, and adding that image URI to the image section. Since I have done that, I can no longer get the CR to do anything except immediately fail once I deploy it.Any suggestions on how I can successfully deploy dynakube, or pointers in what may be the problem?
Hello @SteveO,
In this case, it would probably be best to open a support ticket.
