Error with OneAgent Instalation
Hello everyone,
Yesterday I was doing a new instalation on 15 servers RedHat and I have a problem on 3 of them, this kind of servers are load balancers and integrations servers, but the configuration about the others servers are the same.
I have this error and I try to open a case with support but is really slowly:
13:28:14 Storing SELinux policy sources in /opt/dynatrace/oneagent/agent.
13:28:17 Installing SELinux dynatrace_oneagent module, this may take a while…
13:28:26 Error: Failed to remove dynatrace_oneagent_Policy module.
Thanks everyone,
Exoluxer
Did you examine the installation log? Located in /var/log/dynatrace/oneagent/installer/ unless you changed the path using LOG_PATH.
Yes, I examine the installation log and I see this error
14:59:48 Error: Failed to remove dynatrace_oneagent_Policy module.
Thanks!
It will be easy and fast for you to open a chat discussion or support ticket.
The installer tries to remove the policy by running
semodule -vr "${policyName}"
Try to execute that manually, so:
semodule -vr "dynatrace_oneagent_Policy"
And check the output
Finally I solved this issue updating pcp_package.
Thanks!
