Escaping * wildcard in a DQL Metrics Dashbaord
I can’t seem to escape * on this metric? if I use \ it tells me
There isn’t an escape sequence like `\*`. If you want to use a backslash, use `\\` instead of `\`.
Hi @Fluffydoom ,
You can use contains and DQL section:
Regards, Deni
Thanks! I think the ToString function was the key I was missing!
