Hello, I’m creating a Dashboard that shows Service and Endpoint metrics. It first loads up every endpoint for a Service, but I have an $Endpoint variable that has a Default value of “*”. In my tile, it fails when an Endpoint isn’t selected and it’s using the Default value. Could someone help me out on how I should structure the DQL to not fail on a wildcard, or if it’s another route I should be taking.
Hello, thank you very much for the quick response. I tried out the DQL but unfortunately, it doesn’t return anything when the wildcard is used in the Variable.
