Hi Folks,
I am just learning DQL…
How can I expand this timeseries with a new column including the stdout.message dimension value?
Thanks in advance.
Best regards,
János
Hi @Mizső ,
stdout. message is a dimension of the metric log.uat8.xxx ??, if yes normally it should work with your query. However, if you add a new dimension that the metric does not contain, the output table from the query will return null values for that dimension.
I wonder, after adding the dimension in DQL, did you click the Run button
Thanks for your response. Finally this morning I found the probelm.
It seems these are the same DQL queries but the visualization results different.
I do not understand why was the stdout.message was hide in the first case… good to know the about the hidden columns
After removed “hide” from the stdout.message the result was the excpected:
Best regards,
János
