Expanding Multiple arrays
I am trying to expand multiple arrays in 3 separate columns (“Host_Metric”, “Start” and “End”). Each array in all 3 columns has 97 elements.
I am trying to expand each of the arrays into records. However, when I used the “expand” command, each array element keeps multiplying with the elements of the other arrays, creating many duplicates with wrong information.
I simply want to expand all 3 arrays into their corresponding 97 records with their indexes in the same order. Is this possible?
Do I understand you correctly that:
1. you have three arrays: a = [1,2] , b = [3,4] , c = [5,6]
2. you expect the output to be:
a | b | c
1 | 3 | 5
2 | 4 | 6
if so, the iCollectArray function and the following query can help you:
data record(
  a = array(1,2,3),
  b = array(4,5,6),
  c = array(7,8,9)
| fields all = iCollectArray(record(first = a[], second = b[],third = c[]))
| expand all
| fieldsFlatten all
I created a demo for you in the Security investigator in our Playground as well, you can access it at Dynatrace
Does this solve your problem?
Thank you. This solved my problem.
