Extension Mongo DB Atlas
Good morning, community. A demo was conducted creating a database in MongoDB Atlas, and the configurations were made in the Dynatrace extension. However, a message like this appears on the dashboard.
Although there are two projects in the database.
And this is the extension’s configuration:
    "value": {
      "enabled": true,
      "description": "Ultragorup",
      "version": "2.0.15",
      "featureSets": [
        "database-size",
        "system-memory",
        "process-index",
        "process-document",
        "process-op-execution",
        "process-cache",
        "process-ticket",
        "process-journal",
        "process-other",
        "process-cpu",
        "process-connections",
        "process-global",
        "disk-latency",
        "process-opcounters",
        "process-query",
        "full-text-search",
        "process-memory",
        "disk-space",
        "system-cpu",
        "disk-iops",
        "system-network",
        "process-oplog",
        "process-assert",
        "database-count",
        "process-network"
      "pythonRemote": {
        "project_id": "67d80398c571837ff3f04231",
        "api_url": "https://cloud.mongodb.com/api/atlas/v2",
        "public_key": "dbnfkldx",
        "private_key": "***799***",
        "fetch_events": true,
        "use_proxy": false,
        "verify_ssl": false,
        "use_certificate": false,
        "event_types": null
      "dtAttributes": {}
    "scope": "ag_group-default"
Hi @carlos_carreno,
Have you checked the extension debug log?
János
Hello!
Have you verified that the IP(public) addresses of your Activegates were white listed? and that your Keys are associated to a project/cluster? another thing you need to consider is to make sure is the permission of your account (organization read only). Hope this helps
