mongodb replica set monitoring.
Hi Team
Please share the steps to configure mongodb replica set monitoring.
In one of my environment server monitoring is working fine but not able to get metrics for databases, is there any log location which can we refer for troubleshooting.
Anurag
Are you getting those metrics using some extension?
Best regards
Thanks AntonPineiro for response.
Regarding monitoring issue, i am working with support.
Kindly help me to share link to "how to enable monitoring of MongoDB replica set from scratch [detail steps] using MongoDB (local or remote monitoring) extension
Thank you
Regards
Anurag
If you are using DT extension,  I would check Extensions 2.0 logs.
Best regards
Hi
Kindly help me to share link /steps  "how to enable monitoring of MongoDB replica set from scratch [detail steps] using MongoDB (local or remote monitoring) extension
anurag
Is that metric covered already out-the-box by mongodb extension?
Best regards
Hi AntonPineiro,
Thanks for your reply .My objective to configure monitoring of MongoDB replica set thru Dynatrace.
I am looking for Dynatrace document and link which will guide me to follow steps to configure MongoDB monitoring on Linux server from scratch.
Anurag
Ok, I understand now. I would say:
  1. Check if actual mongodb extensions are covering that metric.
  2. If not, extend metric observability. Maybe Metric scripting integration or Metric ingestion API are flexible enough.
Best regards
