Extension SAP GUI and ABAP Platform
Hi Team,
Can you help, please?
I am configuring the SAP ABAP extension, it shows me the status ok.
I don’t see any configuration errors in the logs.
The dashboard does not show any metrics.
Can someone help me understand why the metrics are not displayed?
Regards
I would suggest you checking ActiveGate logs directly from ActiveGate logs. Sometimes log viewer is not showing all lines.
If you do not have access to target ActiveGate, you can generate ActiveGate diagnostics, it will contains all logs.
Best regards
Hi AntonPineiro
I’ve already seen the error in the activegate log in the extension section.
Thank you very much for your support
Regards
Hi, I have the same case with this configuration. Is there a specific log that we need check to errors.
It depends your installation, you can check default directories here.
Best regards
