SAP ABAP Extension
<span class="">Hello, good afternoon, I have a problem with the SAP ABAP extension where I can see certain metrics, that is, I receive information but some metrics such as:
<br>sap.rfcIncomingRequests
sap.rfcOutgoingRequests
sap.rfcIncoming execution time
sap.rfcOutgoing execution time
SAP.job.status_count.gauge
SAP.job.avg_duration
SAP.job.max_delay
SAP.job.avg_delay
I do not receive information, within the documentation I see that for these metrics an API token is used which has already been created, JCo is also already installed but I still do not receive information on said metrics, I do not know if anyone has had the same problem if you could guide me.</span>
Did you check the boxes in the configuration to send rfc and job information? Have a look at the ActiveGate logs (in the remoteplugin, sap folder) for clues about if something is wrong. You can also open a support ticket.
Thank you, it was only the API-token that was wrong, reviewing the logs we realized that it was that part that was failing, thank you very much for your response and your time.
greetings.
