extract java script errors to csv
hello, how to extract javascript errors from dynatrace to csv file?
Hi @dharma
With User sessions query: select name,count(*) from usererror GROUP BY name  you will get the list of errors
With User sessions API - GET Table you will be able to get a json output of this query
From json to csv just look for a convertor and you are done
HTH
Yos
