JavaScript Errors traces query
Hi there, I’m creating some queries on user sessions, so I can count the JS errors, but I can’t get more details like the image
Could I get JS errors details on User Sessions?, or what do I need to do?
Basically we are migrating from other monitoring app to DT, currently we are using a query like this
SELECT count(errorMessage) FROM JavaScriptError FACET domain, errorMessage WHERE requestUri != ‘/web/chart’
and that is enough to grab all the JS errors with details
@AlexDev Yes, you can get the JS Error details on User Session page, select the Error Type from “Filter by” option
Tijust
Hello @AlexDev
In simple way if you want to get JS error count.
Follow- Select your application --> scroll down --> under top errors --> select JavaScript
post click on JavaScript this view will be presented.
From here you can use filters and create your own metric
Cheers!
RN
This is the solution :slightly_smiling_face:
Thanks​:wink:
