Failed to start Dynatrace Firewall
Hello
After upgraded RedHat 9.5 (kernel-5.14.0-503.11.1.el9_5.x86_64) the  dynatrace-firewall.service has been Failed
How could I fix the problem ???
dynatrace-firewall.service - Dynatrace Firewall settings
Loaded: loaded (/etc/systemd/system/dynatrace-firewall.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Wed 2024-11-13 10:48:24 CST; 1min 28s ago
Process: 2567 ExecStart=/opt/dynatrace-managed/firewall/services/firewall.sh start (code=exited, status=1/FAILURE)
Main PID: 2567 (code=exited, status=1/FAILURE)
CPU: 203ms
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2871]: Error: Could not process rule: Operation not permitted
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2871]: insert rule inet firewalld filter_INPUT jump dt_filter_INPUT
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2871]:                  ^^^^^^^^^
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2878]: Error: Could not process rule: Operation not permitted
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2878]: insert rule inet firewalld filter_FORWARD jump dt_filter_FORWARD
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2878]:                  ^^^^^^^^^
Nov 13 10:48:24 MX2DY02BSAB firewall.sh[2567]: Adding rules … failed.
Nov 13 10:48:24 MX2DY02BSAB systemd[1]: dynatrace-firewall.service: Main process exited, code=exited, status=1/FAILURE
Nov 13 10:48:24 MX2DY02BSAB systemd[1]: dynatrace-firewall.service: Failed with result ‘exit-code’.
Nov 13 10:48:24 MX2DY02BSAB systemd[1]: Failed to start Dynatrace Firewall settings.
Redirecting to /bin/systemctl status dynatrace-nodekeeper.service
@Gerardo_FO Please see below
https://community.dynatrace.com/t5/Heads-up-from-Dynatrace/Dynatrace-Firewall-service-fails-to-start-on-Managed-cluster/ta-p/263165
Hello @Gerardo_FO
In addition to the provided guidance by @p_devulapalli
PFA resources for further troubleshooting:
Run the attached commands:
  • systemctl status dynatrace-firewall
    systemctl stop dynatrace-firewall
    systemctl restart dynatrace-firewall
Proceed with cluster Operations:
If you need to simulate another scenario feel free to review:
Hoping it helps.
BR,
Peter
