File Check Extension for AIX
Hi Team!
Any plans for File Check Extension be available for AIX ?
I haven’t tried but I believe Linux version should not works…
Thanks!
AIX can currently not run extensions. While this may change in the future it’s not certain if that would allow for the file check extension to run on AIX as it is a data source question.
You can create an RFE on the forum for extension support for AIX if you want to increase the visibility and track it.
