Dear All,
Are any available APIs to work with the AIX kernel extension?
Babar
Dear All,
Babar
Use the Settings API with the schema builtin:host.monitoring.aix-kernel-extension to manage this setting.
Hello @Julius_Loman
Thank you for your comments.
I can see only the Get method. Am I missing something?
Babar
Sure, there is a POST method to set the setting, you can even see examples of the API calls in the UI:
