Hi
I see many pages to filter traces by request attribute but is there any way to filter by span attribute?
Thank you in advance!
Hi
Yes, if you define a request attribute with the span attribute as source. It has a limitation - it needs OneAgent and does not work if OpenTelemetry traces are ingested using OTLP.
Thank you Julius, and is there any way to do it in old requests? just tried it and I see that attribute only in new ones
edit: marked as solved because either if there is a way or not the original question is already solved
