Filter using span Attributes for OTEL ingested traces
We are ingesting OTEL traces into dynatrace and want to filter using span attributes.We are not able to filter based on span attributes.Please let us know if this is possible.We are using dynatrace managed version.
Tarun
The span attribute needs to come in as a Request Attribute. If you are ingesting the traces into Dynatrace by utilizing the OneAgent, you can capture the spans via the Request Attribute, but not if you are using the API.
Check your span settings: Span settings — Dynatrace Docs
You can do filtering with Request Attributes as @Taylor-Sanchez wrote: Request attributes in Services — Dynatrace Docs
Radek
