Hi, I want to view metrics of only 1 process by filtering by it’s process id. However it is not able to find any data w.r.t this process. Is there a way I can achieve this? The process id exists as seen in the below screenshot.
Hi @Mik
As much as possible you can do it. You can prepare such a view with Data Explorer. You need to set for the selected metric Splitting by processes and in the filter you indicate the process name.
Radek
Thanks a lot for quick response!
Is there a way to query the process by its PID based on the process id generated on the host machine?
The reason I am asking this is because I am having many processes having the same process name, to individually go to each process to find out which one I am looking for, get it’s id from the URL and then use it in the dashboard filter seems a bit of a tedious task
You can use an advanced mechanism to group processes: Process group detection — Dynatrace Docs.
You will be able to build a process detection rule to suit your needs.
