Hi everyone
Please tell me, I have a custom java service and kafka queues are connected to it, how do I use them to make a filter in the dashboard so that it works like this:
I want to watch a custom service in the context of the queue
If you go to the service itself, you can make a filter for the service, but how to do it on the dashboard
Or how can you beat it?
Thanks in advance!
P.s examples of screenshots in the attachment
Ahh okay, so you want to filter by way of the filter in the dashboard. i dont think you can use the out of the box filters per say but you can make a custom one. Select the custom dimension:
target the request type and the service:
you can also call the custom queues too:
@ChadTurner Hello
I already tried this option and added it to the dynamic filter, but when I display it on the jshboard and select the queue I need, it does not filter anything and nothing happens, unfortunately
So if your filter is set up like this and your tile doesn’t have any subfilters on it, you might want to toss in a Support ticket as it should be filterable.
