Hello.
I have an application running on Linux VM host, happily full-stack monitored, technology looks supported. Though I don’t see in Dynatrace the outgoing connections either from app nor from VM host it is running on, to my ldap service.
I suppose I should see them kind of at code level or at requests level ? Or am I mistaken because say it is ldap:// protocol as opposed to http[s]:// protocol ?
Any trick known ?
Regards.
Hello @gilles_tabary
Regarding the highlighted concern:
- As long as the servers are monitored in full-stack monitoring mode, you will be able to get insights regarding the infra and code-levels as well.
- You well be able to view the calls to the LDAP Services under requests to un monitored hosts, in case the LDAP Servers are not monitored in Dynatrace.
- If the LDAP Servers are monitored using DT Oneagent you will get full visibility into LDAP Services.
- You can see the full service calls through the service Flow on the services level, on the host level you can inspect the process group connections as well.
- Service flow in Services Classic — Dynatrace Docs
Regarding LDAP monitoring you have option through the Hub:
Hoping it helps.
BR,
Peter.
Hi. Thanks. You perfectly got the question :slightly_smiling_face:
Mystery:
I don’t see the Service Flow as documented @ Service flow in Services Classic — Dynatrace Docs
I don’t see host outgoing connections to my LDAP.
I don’t see PG / PGI outgoing Process connections to my LDAP.
I went to inspect PG services > requests > outgoing > trace > service flow : nothing visible.
The ticket I opened with the support is not helping for now. For now I am baffled.
Have you checked if the processes are fully monitored in your case. For example in the screenshot below, some processes need a restart[yellow icon] and some of them have other issues[one with “i” icon]
Thanks for feed back / idea.
That’s the crux of my issue : my host is reported full-stack. We rebooted host. My PG is reported as instrumented fine (no warning icon, no info icon). AFAIU the technology of my PG is known and supported by OneAgent full-stack / injection function.
Maybe I am missing something more conceptual, which would explain I cannot see these connections.
Hi @gilles_tabary
Kindly ensure:
- The Process group deep monitoring is enabled on the target process groups.
- The process groups technologies are supported or not to avoid long-time troubleshooting the issue.
- The oneagent features regarding these technologies are enabled properly && required service restart is conducted correctly.
- The Platform and monitoring components “Cluster nodes, Oneagents, ActiveGates” are up to date.
Ensure no blocking for the Dynatrace headers from the Firewall or network sides: Infrastructure pass-through requirements for RUM Classic — Dynatrace Docs.
Hoping it helps.
BR,
Peter
Hi.
It turns out ldap:// connection protocol is not yet monitored by Dynatrace (information obtained from support).
There is an RFE Request to add capabilities to monitor LDAP protocol.
Regards.
