Hello all,
I’m currently having environment with topology like this:
Front-end App server (EC2) → AWS Network Load Balancer (NLB) → Backend Server (VMWare On-Premise)
So I used AWS NLB provided rule to forward my app traffic to on-premise server.
After I deployed OneAgent in Front-end server and Back-end server I couldn’t see connection between them.
Is there any rule or header that I could apply on my AWS Load Balancer so the service flow can be detected?
Or actually by enabling fullstack monitoring on both server are enough?
Thank you
@agylpradipta,
Are you using Infrastructure mode? If that is the case, it is normal that you don’t see requests between them.
Yap after I re-check, server on my on-premise environment still on Infra Only mode. Will try to enable the full-stack monitoring mode.
So actually there is no problem regarding the AWS Load Balancer?
There are no problems with any kind of proxies\balancers\web server - balancers if they are not block headers.
If you have some balancers \ proxy which block or delete \ modify header x-dynatrace - there will no correct serviceflow. From Documentation you need only header x-dynatrace, other headers related to RUM\UEM.
I agree with Antonio - problem is related that agents are not in full stack mode. Front web-servers not instrumented. Change monitoring mode, restart frontend process and you will see correct service flow.
Romanenkov Alex
