GCP Monitor on Cloud Run instead of GKE
GCP Monitor used to be offered as a GCP function, and later became standardised as a k8s deployment.
With the capabilities of Google Cloud Run - could the gcp-monitor be hosted in Cloud Run?
Hello @benj5656 thank you for your inquiry, the (current) Dynatrace GCP integration was purpose-built for GKE. Cloud Run is not a supported integration deployment option, we will sure track this ask on the community.
We highly appreciate the feedback.
