When configuring the Generic Cisco Device extension I have this error message:
Failed to assign monitoring configuration to ActiveGate. Reason: Extension com.dynatrace.extension.snmp-generic-cisco-device(1.4.6) not available in cache yet (queued for download)
When executing the dynatracesourcesnmp utility from the ActiveGate with the snmpwalk and snmpget parameters to the router I get a correct response in both cases (statusCode=0)
If anyone had this error and was able to correct it, I appreciate your help. Thank you
