Asking for your help. We have a manged environment running version 228. We have on a single environment ActiveGate which was automatically upgraded to version 227. I have enabled the cisco snmp plugin (version 224 was enabled) and we’re trying to make it work but failed so far. I’ve started digging around and found the following:
1. In the log files we see the message that it cannot find dynatrace/remotepluginmodule/agent//config/extensions
2. When using the REST Api to retrieve the configuration The only event is “Failed to assign monitoring configuraion to Active Gate, fast check status: NO_SUITABLE_ACTIVE_MONITOR, reason: No Active Gates capable of handling given technology available”
Since there is only one active gate it is in the Default group.
As we discussed 1 one 1, the issue was that the Cisco Generic Device extension version 1.2.4 that you had installed has a minimum Activegate version of 1.228, while your Activegate was 1.227.
We are working on adding version 1.2.3 and prior to the Hub, so that you can chose an older version that is compatible with your AG, for the meantime I’ve provide you with the 1.2.3 zip file directly.
Version 1.230 of Dynatrace also provides a clearer error message when that happens.
Also keep in mind that the extension version “224” doesn’t exist, the version can be seen on the interface as “1.2.4”
Installed 1.2.3 and waiting for the results. Thank you. That being said, I find it weird that an extension is uploaded to the hub when it’s requirements are not available to customers. Active Gate 228 wasn’t available even on saas when the 1.2.4 was released publicly to our instances.
Hello David, is there any document refer to the value of monitoring NW & security devices with DT rather than any NW monitoring tools (please send the link to my email mohsamibr@gmail.com)…thanks in advance
