I’ve added an extension to monitor Oracle Database but the error is stating that it needs ActiveGate version 1.265.0 or later. So, is there a possibility to get a beta version for the upcoming AciveGate version so that testing from our side can be fulfilled?
Sounds like the AG cannot connect to the DNS/IP you entered in the configuration. Try a telnet from the AG to see if that works. You should probably create a support ticket for this.
