Is there a way to view all Monitoring candidates? maybe extract them in a list ?
thanks
Craig
thanks
Craig
You can use the Dynatrace API to get list all the hosts. You can choose state of this hosts (example: monitoring candidates (isMonitoringCandidate)).
Radek
As @radek_jasinski states you can use this API Call
{{baseUrl}}/entities?pageSize=500&entitySelector=type(HOST),isMonitoringCandidate(true)
This is exactly what I meant ![]()
