Hey,
Some of our tenants are missing the property “isMonitoringCandidate” on the /entity/infrastructure/hosts API v1. Does someone have a fix for this?
Hey,
Hi Community! What could be source of the problem highlighted in this thread? Would be great to solve this, cheers!
@marius_duns As far as I know, with the “old” API you are using, this attribute is present only on hosts which are not monitoring candidates. Likely you don’t have monitoring candidates in those environments.
Also, consider using the Monitoring Entities v2 which is far more powerful.
