Hi, I need to build a custom ActiveGate plugin to monitor the URLs. What are my options to get started?
Take you hands-on here: Develop your own Extensions — Dynatrace Docs
There are plugin examples that you can start with.
And I guess here’s the API you want to consume with plugin:
Can’t you use HTTP monitors? Which protocol do you want to support?
We are trying to poll applications behind SAMLv2 SSO. Also, customer is expecting to avoid DEM consumption.
