ActiveGate for Synthetics with the RemotePluginModule
I have a Windows Activegate for running synthetics.
I want to install the 3rd Pary extensions on the same server.
(dynatrace-api/third-party-synthetic/active-gate-extensions at master · Dynatrace/dynatrace-api (github.com))
Is this possible ?
Lee
No, it is not. You need to have a dedicated ActiveGate to Synthetic or to Extensions. The main reason is the performance and resilience - you don’t want that extension workload overloads the ActiveGate and prevents running Synthetic checks and the other way round.
