Hi all,
I currently just started with my first synthetics but our plan is to integrate the on demand triggers in GitHub Actions and then read if it passed. I know Dynatrace has a GitHub actions integration but I can’t find anything on if we can also access the synthetics.
In short:
- Trigger synthetic action in GitHub Actions
- Wait for result and either pass or fail pipeline based on result
I also know there is an API but I would rather use a pre-made solution.
Thanks in advance!
