Hello, can someone please tell me how to calculate the ddus consumption for the integration with K6? Thanks in advance for your answers. It would be by the number of records returned in the results report generated by K6?
Hi @santruan,
You can find useful infromation about ddu consumption in the documnetation:
DDUs for metrics | Dynatrace Docs
Most important sentence: Each ingested data point deducts 0.001 DDU from your available quota.
I guess you would like to ingest perfromance tests result metrics.
I hope it helps.
Best regards,
Mizső
Hi @Mizső. Thank you very much for your answer.
