Licensing Consumption
Hello Guys!
I need to fill a Dynatrace excel with some data to predict the consumption for next year.
Mainly DDU and DEM questions. We use Grail logs
How can i find out?
FOR DDU:
- How many GB of logs are ingested per day?
- How many data from logs to Charts and Dashboard?
- How many days of Retention Time.
FOR DEM:
- Unique Synthetic actions
- # of executions per hour
- # of locations to execute from
Thanks guys
Hi @John_ ,
For DDU Consumption, you may wath it in this url :
https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.classic.consumption/ui/consumption/ddu/
Hey @gbaudart .
Thanks for your reply. But the problem for me is that it gives me values in ddu consumption and not GB of logs for example.
How can i answer this?
DPS or Classic Licensing?
The DPS section in the Dynatrace Docs has a quite extensive Log Management and Analytics page.
Changing from classic to dps.
Only problem is i can’t seem to find some informations that are asked.
Going to check your docs.
Data from Logs to Charts and Dashboard 0,00% 0% of all log messages result in a metric data point
Any idea how to get this… can t seem to find? Data from logs to charts and dashboard.
DPS Template created here: https://community.dynatrace.com/t5/Open-Q-A/DPS-Dashboard-Built/td-p/232878
