Has anyone pulled in OCI (Oracle Cloud Interface) metrics?
We are using Oracle Load Balancers which are located in the cloud and managed through the OCI Console. Has anyone worked with ActiveGate to pull in these metrics?
The Active gate plugins are very easy to implement to retrieve any metric, please take a look at the tutorial Develop your own Extensions — Dynatrace Docs. You could use that example and change the metrics retrieved for the ones that you want.
Best regards
OCI extension Preview is out. Please have a look at https://www.dynatrace.com/hub/detail/oracle-cloud-infrastructure-preview/?query=oracle+&filter=all - it’s ready for a test drive. Mind its “preview” status: it has limitations and things may break. Feedback welcomed, preferably through https://community.dynatrace.com/t5/Feedback-channel/OCI-Oracle-Cloud-Infrastructure-An-extension-Preview-release-is/m-p/239520#M3113
