Hi everyone,
I hope you are doing well.
Recently, we attempted to integrate our OCI services using the Dynatrace extension, but without success.
After several failures across numerous attempts, we noticed that the documentation doesn’t seem to support our OCI version. Even with the ActiveGate installed and the credentials created, we couldn’t reach the OCI ports. It appears that the application does not expose these ports to the internet.
Has anyone experienced this issue before and could suggest an alternative solution?
Thanks in advance.
Best regards,
