Helm - Dynatrace Operator installations compatibility with OCP 3.11
there is a new update of the best approach about how to install Dynatrace in Openshift like Operator. It talks about using Helm package manager. I am missing a section on this page about minimal OCP version supported with Helm.
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/openshift/other-deployments-and-configurations/understanding-openshift-deployment-strategies/
Looking for that information it seems that Helm is not supported for OCP 3.11 and Operator installation should be done as a regular one.
Have you used Helm for 3.11 OCP versions?
Thanks in advance.
Alberto.
Hi there. Make sure you are using Helm 3. It should work on OCP 3.11, though there is a bug prior to OCP 3.11.188 as documented here:
Red Hat fixed the bug here:
And you can make things work properly (if you are on an earlier version) by deleting this line here:
Hope that helps
Note: we are adding this to our help pages shortly.
