Help with YAML customization for Microsoft SQL Server Extension
If possible, i need help with something related to the YAML of the extension. I was editing it for a custom extension using the same data source. I was trying to edit a query which is used for the database state, to get information for a specific database. My question:
1. I created a variable with perItem: true
so that i can define it in each endpoint, which is called:
- id: database    displayName: Database Name    perItem: true    type: textthis is the query:
metrics:          - key: sql-server.databases.state            value: col:state        query: >-          SELECT            name                  AS database_name,            state,            state_desc,            recovery_model_desc,            user_access_desc,            is_auto_close_on,            ISNULL(              DATABASEPROPERTYEX(name, ‘Updateability’),              CASE                is_read_only                WHEN                  0                THEN                  ‘READ_WRITE’                ELSE                  ‘READ_ONLY’              END            ) AS updateability          FROM            sys.databases          WHERE            name = 'var:database’I tried it like that with ‘var:database’ and with ${var:database} and both didn’t work. Does anyone know a way to dynamically put the information there?
I think “trick” should be easy.
In Extension 2.0 you can’t inject variables inside the SQL text. Instead, you run the query “wide” and then filter the dimension using your per-endpoint variable. That’s the supported pattern.
here is documentation:
Extension YAML file
So, in your yaml:
vars:
  - id: database
    perItem: true
    type: text
sqlServer:
  - group: Database state
    query: >-
      SELECT
        state,
        state_desc,
        user_access_desc,
        is_auto_close_on,
        ISNULL(
          DATABASEPROPERTYEX(name, 'Updateability'),
          CASE WHEN is_read_only = 0 THEN 'READ_WRITE' ELSE 'READ_ONLY' END
        ) AS updateability
      FROM sys.databases
    # Map the name as a dimension and filter it by the variable
    dimensions:
      - key: mssql.database
        value: col:database_name
        filter: var:database
    metrics:
        value: col:state
        type: gauge
Then, in each endpoint’s monitoring configuration, set database to the specific DB (e.g., AdventureWorks). The filter will keep only rows where mssql.database equals that value. Filters can use variables (var:<id>) or constants and are applied at the dimension level; they don’t rewrite the SQL.
Please try this and let me know if it works. Unfortunately, I don’t have a way to test it myself.
