HIVE and Apache NiFi Metrics
Has anyone stumbled upon an extension and/or capability to capture HIVE and Apache NifI Metrics?
To clarify they want HIVE and Apache NiFI Metric including but not limited to
Read/Writes
FlowFiles In
FlowFIles Out
Input/Output Ports Load
Hello, is anyone familiar somehow with the subject outlighted above? Thank you for any feedback in advance!
We were able to develop an extension to capture these metrics. Extensions capabilities allow you to monitor any metric that is not OOTB
Hi @echwallah did you achieve it via JMX plug-in?
Thank you for your answer
Hive metrics I used JMX and Apache Nifi was a OneAgent extension
@echwallah did you publish the extension you created for monitoring Nifi? If not is it something you would be willing to share?
