Honeycomb dashboard for a specific application
How can i create a honeycomb Dashboard for just one application with problem? Just like this, when rise a problem, the Comb color changes to red.
Are these cells the application services? If yes then it will become red when a problem arises
Hi @ArtuD,
I often use two methods for one app health visualization for management dashboards:
1. I create a Management Zone with the Web app or any app. And then filter the dashboard tile for this MZ:
2. I filter the problem view for the required app and then pin it to a dashboard.
I hope it helps.
Best regards,
Mizső
