I would like to add a single value visualization to my dashboard that takes the average availability of all hosts in the selected management zone. I can create a metric in data explorer after selecting one of the hosts in the management zone but the query is very specific to the host I select. Can this value be dynamically updated each time I change the management zone.
You can add dynamic filters to Classic Dashboard or variables to new Dashboards (Grail).
Best regards
Thanks. The dynamic filters solve for individual host metrics but I still need a query that captures avg of availability for all hosts that are part of the management group that is selected.
If I select a host from the management group I can drill down to its availability and open in Data Explorer:
(builtin:host.availability.state:filter(eq(“dt.entity.host”,HOST-XXXXXXXXXXX)):auto:sort(value(sum,descending)):splitBy(“availability.state”)/builtin:host.availability.state:filter(eq(“dt.entity.host”,HOST-XXXXXXXXXXXX)):auto:sort(value(sum,descending)):splitBy()*100):setUnit(Percent)
but that is the availability specific to that host. If my management zone had 4 hosts or 10 hosts can I get the avg availability of the hosts dynamically?
totally missed the built in metrics… thanks.
