The chart showing the data found that there was data loss
Hey @Lwl can you give us more details about?
Hi @Lwl ,
How’s it going?
Previously, was the data collection correct?
Have you tried doing a restart of OA or AG?
R.
There seems to have been this situation before, but it has not been solved, and now I want to solve it.
I had a similar situation when mcafee antivirus was running on the system. Have you checked the log entries?
Checked the logs, and there’s not much difference between them and normal host nodes
I believe you should report the case to support. You may have many variables as to why this data is not being collected correctly.
Yes, I will do that
