Host List without Management Zone
Hi Community,
I’d like to output a list of Hosts that are not in a ManagementZone.
The EntitySelector does not allow us to do this.
Do you have an idea?
I would say using entities API:
  1. Call entities API to get a full host list.
  2. Call entity API per host ID in before query.
Second one is providing much more information than mz, but you can see if that host has a MZ or not:
Best regards
Isn’t there an easier way to get the information?
This may help, part of a dashboard - not my code, from a DT SME.
import { monitoredEntitiesClient } from '@dynatrace-sdk/client-classic-environment-v2';
export default async function() {
  // Check if that tile should be activated based on selected indicators and scope
  if($Indicators[0] === "All" || $Indicators.includes("hostGroupCoverage")) {
    let scope;
    if($Scope[0] === "Tenant") {
      scope = 'Tenant';
    } else {
      let mzList = "";
      for(let i=0; i<$Scope.length; i++) {
        mzList += i === 0 ? `"${$Scope[i]}"` : `,"${$Scope[i]}"`;
      scope = mzList;
    // Define entity selector based on the selected scope
    let entitySelector;
    if(scope === "Tenant") {
      entitySelector = 'type("HOST"),isMonitoringCandidate(false)';
    } else {
      entitySelector = `type("HOST"),isMonitoringCandidate(false),mzName(${scope})`;
    let config = { from: `now-1d`, entitySelector: entitySelector};
    // Get all monitored hosts
    const monitoredHosts = await monitoredEntitiesClient.getEntities(config);
      entitySelector = 'type("HOST"),isMonitoringCandidate(false),fromRelationships.isInstanceOf(type("HOST_GROUP"))';
    } else {
      entitySelector = `type("HOST"),isMonitoringCandidate(false),fromRelationships.isInstanceOf(type("HOST_GROUP")),mzName(${scope})`;
    // Get all monitored hosts that are assigned with a host group
    const hostsWithHostGroup = await monitoredEntitiesClient.getEntities(config);
    // Compute host group coverage
    const hostGroupCoverage = parseInt(hostsWithHostGroup.totalCount/monitoredHosts.totalCount*100);
    // Compute local score based on the host group coverage
    const score = hostGroupCoverage === 100 ? 1 : (hostGroupCoverage >= 80 ? 0.5 : 0);
    let result;
    switch(true) {
      case score === 1:
        result = `✅ ${hostGroupCoverage}%`;
        break;
      case score === 0.5:
        result = `💡 ${hostGroupCoverage}%`;
        break;
      case score === 0:
        result = `⚠️ ${hostGroupCoverage}%`;
        break;
    // Return the emojied result
    return result;
  } else {
    return "N/A";
Maybe easier can be using Grail, if it is enabled in your tenant. I think you know more Grail than mine but something as that:
fetch dt.entity.host
|  expand managementZones
|  filter managementZones == ""
Best regards
hi @PraWij,
Thanks for this code.
OK, but what are the $Indicators and $Scope variables?
@AntonPineiro
This doesn’t work. I’ll try with the sdk
In the full dashboard, scope also includes the mgmt zones.
Indicators example:
You can try this one, looks like is working:
| fieldsAdd managementZones
| filter isNull(managementZones)
Best regards
This looks interesting,
What do I need to add to search by a particular management zone?  contains or equal? need the DQL.
Maybe more than one option but looks like this:
| filter matchesValue(managementZones, "XXXXXX")
Best regards
@AntonPineiro This works for me. Thanks a lot.
Tijust
You are welcome!
