unfortunately, there is no such option from the GUI.
The only thing I can suggest is retrieving this data via the API.
First, list all entities by type, then for each entityID check if it has an assigned MZ.
Below, I’m pasting a script that will list this for you.
#!/usr/bin/env python3
import os, csv, json, time, re, argparse
import requests
from concurrent.futures import ThreadPoolExecutor, as_completed
# CONFIGURATION (CHANGE HERE)
DT_BASE_URL = "https://dynatrace/e/tenantid" # WITHOUT /api/v2 at the end
DT_API_TOKEN = "dt0c01. API TOKEN" # token with "Monitored entities – read" permission (API v2)
# Types you want to check
TYPES = ["APPLICATION", "HOST", "SYNTHETIC_TEST", "HTTP_CHECK", "CUSTOM_DEVICE"]
# Files
OUT_CSV = "unassigned_entities.csv"
OUT_JSON = "unassigned_entities.json"
# Technical parameters
PAGE_SIZE = 500
TIMEOUT_SEC = 30
MAX_WORKERS = 8
def _normalize_base_url(u: str) -> str:
if not u:
raise RuntimeError("DT_BASE_URL not set")
u = re.sub(r"/api/v2/?$", "", u.strip())
return u.rstrip("/")
def _headers():
return {
"Authorization": f"Api-Token {DT_API_TOKEN}",
"accept": "application/json; charset=utf-8",
def list_entity_ids(base_url: str, entity_type: str):
"""Step 1: Returns a list of entityIds for a given type"""
ids = []
next_key = None
url = f"{base_url}/api/v2/entities"
while True:
if next_key:
params = {"nextPageKey": next_key}
else:
params = {"entitySelector": f'type("{entity_type}")', "pageSize": str(PAGE_SIZE)}
r = requests.get(url, headers=_headers(), params=params, timeout=TIMEOUT_SEC)
if r.status_code == 429:
time.sleep(1.0)
continue
r.raise_for_status()
data = r.json()
for e in data.get("entities", []):
eid = e.get("entityId")
if eid:
ids.append(eid)
next_key = data.get("nextPageKey")
if not next_key:
break
return ids
def get_entity_details(base_url: str, entity_id: str):
url = f"{base_url}/api/v2/entities/{entity_id}"
params = {"fields": "+managementZones,+tags,+firstSeenTms,+lastSeenTms"} # <= FIX
for attempt in range(5):
time.sleep(0.5 * (attempt + 1))
continue
if not r.ok:
return {
"entityId": entity_id,
"type": "",
"displayName": "",
"firstSeenTms": None,
"lastSeenTms": None,
"managementZonesCount": None,
"error": f"{r.status_code} {r.text[:1000]}",
data = r.json()
mz = data.get("managementZones") or []
return {
"entityId": data.get("entityId", entity_id),
"type": data.get("type", ""),
"displayName": data.get("displayName", ""),
"firstSeenTms": data.get("firstSeenTms"),
"lastSeenTms": data.get("lastSeenTms"),
"managementZonesCount": len(mz),
return {
"type": "",
"displayName": "",
"error": "Too many 429s",
def main():
base_url = _normalize_base_url(DT_BASE_URL)
if not DT_API_TOKEN or DT_API_TOKEN.startswith("dt0c01.xxxxx"):
raise RuntimeError("Set the correct DT_API_TOKEN in the script header")
all_ids = []
per_type_counts = {}
# Krok 1 — listing ID
for t in TYPES:
print(f"[INFO] Step1: listing the ID for the type: {t}")
ids = list_entity_ids(base_url, t)
per_type_counts[t] = len(ids)
all_ids.extend(ids)
print(f"[OK] {t}: {len(ids)} entity")
# Krok 2 — szczegóły
print(f"[INFO] Step2: fetching details of {len(all_ids)} entities in parallel ({MAX_WORKERS} threads)")
details = []
unassigned = []
with ThreadPoolExecutor(max_workers=MAX_WORKERS) as ex:
futures = {ex.submit(get_entity_details, base_url, eid): eid for eid in all_ids}
for f in as_completed(futures):
rec = f.result()
details.append(rec)
if rec.get("error"):
print(f"[WARN] {rec['entityId']}: {rec['error']}")
continue
if rec.get("managementZonesCount", 0) == 0:
unassigned.append(rec)
# Save
fields = ["entityId", "type", "displayName", "firstSeenTms", "lastSeenTms", "managementZonesCount"]
with open(OUT_CSV, "w", newline="", encoding="utf-8") as f:
w = csv.DictWriter(f, fieldnames=fields)
w.writeheader()
for r in unassigned:
w.writerow(r)
with open(OUT_JSON, "w", encoding="utf-8") as f:
json.dump(unassigned, f, ensure_ascii=False, indent=2)
# Summary
print("\n=== SUMMARY ===")
for t, c in per_type_counts.items():
print(f"{t}: {c} (all)")
print(f"without MZ: {len(unassigned)}")
print(f"Pliki: {OUT_CSV} | {OUT_JSON}")
if __name__ == "__main__":
main()
