Dear Experter,
I am not sure about the way of Host unit hours work, last week I see my Host unit hours has using overage, then today I just see it release.
Is there any reason of this release or is there specific period to release ?
Before:
Now:
Best Regards,
The question is did you change anything on the environment?
Perhaps you have reduced the number of pod’s or the amount of RAM allocated, resulting in less license utilization.
Here you have details on how Host Unit Hours work:
https://community.dynatrace.com/t5/Open-Q-A/How-to-check-Host-Unit-Hours-HUH-and-which-host-is-consuming/m-p/194553
Radek
