Hi team
I have one query regarding host unit hours(HUH) how to track & which host is consuming HUH ?
How to check in Dynatrace UI?
can you please let us know
Lakshmi Narayana
Hi team
Lakshmi Narayana
The Host Unit Hours is a separate license only from licensing/business perspective. Host consume host units and when you are starting consuming above the limit (purchased host unit licenses) you can consume host unit overages which are the host unit hours.
So when you are consuming up to the number of purchased host units, you are not consuming any of the host unit hours. Any agent connected or reconnected after you hit the limit will consume host unit hours (if they are available to you).
Hi Julius_Loman,
Thanks for the update
I have one more query in our case we are consuming up to the number of purchased host units only. we have enough licences for hosts but why HUH consuming.
Is there any reason.
Can you please let us know
Lakshmi narayana
If you are not reaching your host limit, you are not consuming host unit hours.
So if you have for example 10 HU, and 10 HUH purchased, then:
Hi Julius_Loman,
We are using less than purchased HU, But still HUH are consuming .
we don’t know the reason why happening like this
Lakshmi Narayana
You must reach to DynatraceOne for that. I don’t think the HUH are consumed in your case, since the license display shows you how much have you already consumed from the HUH, not how much are you consuming right now.
Ok Julius_Loman,
Hi Lakshmi,
As Julius said the host unit hours are only consumed when HU are at 100%, it is true that you might see some HUH consumption, but this is not real consumption but rather a calculation of HU translated in HUH. So nothing to worry there. I agree it does confuse customers sometimes.
Kind regards,
Koen Willekens
D1 CSM
Thank you Koen Willekens
Thank you Julius_Loman
