How can i enable the process/vm reboot problems in Dynatrace
Mayana Khan
Reboot isn’t problem itself. But when you will go to process group, that you want to track when it is unavailable (shutdown, restart, crash), you should go to:
Process group of your choice => edit => Availability Monitoring.
You can change default behaviour, when problem is raised if service calls are affected.
