How can I test connectivity by Snmpwalk v2
Am already installed cisco extension and F5 extension and i got from both request timeout, am used SNMP V2 with them
and this site even the telnet is disabled on the device , can any one tell me the SNMPWalk command for V2?
@Eslam_Ismail,
I would first check if you have connectivity from the ActiveGate where you are running the extension. Run snmpwalk from there and if it does not return anything, check it first. Also check that you are using the correct SNMP authentication, as that is one common source or connectivity issues. If nothing works, and you can do it, do a tcpdump and check out the traffic that is going on.
