In ruxitagent_extensionsmodule_xxx.log i found messages like this :
{“extensions”:[{“id”:“snmp”,“extension”:“com.dynatrace.extension.snmp-generic-device”,“tasks”:[{“task”:“-7234474320797872862”,“configurationId”:“750b27da-1633-3d8f-bd40-0c0d9afa1fe5”,“compositionStatus”:“DEVICE_CONNECTION_ERROR”,“message”:"DEVICE_CONNECTION_ERROR: (host=10.63.207.117): connection problem due to wrong community name or network problems.: Query caused a network error with the need to reconnect (host=10.63.207.117): read udp 10.117.72.54:36721->10.63.207.117:161: i/o timeout: GetBulk returned an error: request timeout (after 3 retries) [status code=27] [status code=38] [status code=38]; "}
But when i poll this device with snmpwalk from ActiveGate, it work’s, I retrieve interfaces status… etc.
There is no configuration mistakes (same community, same IP, same ActiveGate).
Is this could be come from plugin GetBulk request? My device coud be not compliant with these requests? In this case ,someone knows how to force extension to use Get Next request?
activated the generic snmp devices plugin and added a configuration with a bunch of devices to monitor.
Running into errors as the log tells me the same things like Oliver described, bulk requests on a specific OID runs into timeout on a devices, which causes the devices from the whole configuration to get inactivated (the icons are greyed out and no data is available, sometimes it works, sometimes not).
My workaround was creating configuration per devices, so no other devices would be affected because one isn’t reachable, but i’m sure it’s not the way it was intended to use.
Already done - seems to be a problem when you got more devices in a single configuration. Having only one device per configuration works better. Got the information it should be fixed in Q3/23.
We have the same issue. If getbulk needs more time to complete why not change the timeout threshold. I guess this means to rebuild the extension with new timeout value. Has anyone done this successfully?
